For years I've planned to do what old Swedish HotRoders used to do when & before I was a kid & they told & showed me pix of...
To get wider (rear) wheels they used to use two rims/side & cut away the narrow part & ad the wide part from another rim, since you only have to do one weld & two extra second hand rims was cheaper than two new strips of steel.
& here's the trick for the front ones: just reverse the center part, then you have wider track but still narrow rubber = not as hard to park without powersteering.
So while I'm looking for two extra rims for in the back I wonder if anyone has a picture of an original rim's "inside" without tire on, not the back side; the inside!
I've googled but to no avail & my own still has tires on.
Pretty please...?
Pretty please...?
