I have found myself in a bind I am trying to install R3 headers into my 56 Skyhawk Passenger no Problem Drivers side Problem these are the new R3 from Stude international. I was considering changing over to a Rack and Pinion system which would eliminate the interference problem.But I don't have any info on this I was told a Buick Rack could be installed fairly easily but which one ?. Any body out there with some Ideas I'm really up against the wall on this. HELP.
Rack and Pinion Steering
Sho, All Buick's are power. The one's to get are from the late 80's through the 90's. If you don't need power use a 97 Chev. Impreza steering box. But you will still need to make your own bracket to hold it and make your own linkage from the column to the box.
Originally posted by Alan View PostSho, All Buick's are power. The one's to get are from the late 80's through the 90's. If you don't need power use a 97 Chev. Impreza steering box. But you will still need to make your own bracket to hold it and make your own linkage from the column to the box.Gary L.
Originally posted by Alan View PostGoogle it. You will find that Chev. imported Subaru's and put Chev. badges on them in 97.Gary L.
Sometimes the first idea that comes to mind is not necessarily the best one.
Deepnhock might just have the answer. You may be able to move the engine over a bit to gain clearance.Last edited by RadioRoy; 02-23-2018, 06:51 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Both of my Skyline engine swaps were pretty tight between the turbo and the steering. In the case of my RX-7, we were able to TILT the engine slightly and get adequate clearance - depends on the nature of the interference. There are more factory cars than you might think that have the engines off center for clearance issues.
My friend Sean has built custom headers for about 40 years, and he thinks nothing of reshaping one or two tubes to get clearance. If you think you have tight clearance issues, this photo will put it in perspective:
ACDELCO 36RO364
buick skylark 1995-1998 chevrolet beretta 1994-1996 chevrolet cavalier 1989-1994 chevrolet corsica 1994-1996 oldsmobile achieva 1992-1998 oldsmobile firenza 1987-1988 pontiac grand am 1985-1998 pontiac j2000 1982-1985 pontiac sunbird 1986-1994
Steeroids sells a center take off rack and pinion with bolt in parts for an early Mustang or Corvette ... but not a Studebaker. Theirs has 6.1 inches of travel and good tie rod (bump steer) adjustments. However, depending on your engine, oil pan clearance can be a problem ... and connections to your particular steering column are affected by the fixed alignment of their rack. I'm custom machining their Mustang center take off plate to get clearance to my custom LS oil pan ... and rotating the rack to (hopefully) use their supplied two steering knuckles with just one thrust bearing. Connecting the rack and bearing to the Studebaker frame does require messing around with their (Mustang/Corvette) brackets. Note: my first attempt used the Corvette plate and required it to be flipped ... making the steering connection sloppy (two bearings) and tie rod connection extended.
jack vinesPackardV8
