Did Studebaker ever mfg a H.P. Intake Manifold for the 289 V8 ? If so will any other 4-BBL carbs work on this manifold besides the WCFB/AFB without modification. I see where SI has an R-1 Air Cleaner
(H.P.) in their catalogue that will fit any Carter WCFB or AFB 4-BBL. Wouldn't the stock 4-BBL 289 Intake Manifold also be considered a square bore. The reason for this inquiry is whether or not a Street Demon 4-BBL carb in a (625 or 750) configuration might work on the Stude 289 4-BBL Intake manifold. I tried a Street Demon 750 CFM version on a Chevy 409 and it was a screamer right out of the box with little or no adjustments. When the air actuated secondaries kicked in it left "little doubt" whether it was working or not. I had to use an Adapter/spacer to work with the Chevy Spread Bore Intake. You just don't see much of anything after market advertised for the Studebaker 289 High Performance , etc. Just wondering what you Performance Guys are doing.
Stuhawk
Stuhawk
