Results 1 to 17 of 17
Thread: Need Overdrive Lockout Cable
    Feb 2015
    Cohasset, MN
    178
    Does anyone have an overdrive lock out cable assembly to sell? The assembly I need goes from the instrument panel to the overdrive unit. It allows the driver to manually turn the overdrive on and off. This is for a 1953 2R5. Thanks!
    1,611
    If you aren't worried about originality, a choke cable from any auto parts store would do the trick. Can get them in most any length and cut to fit.
    Sep 2008
    calgary, alberta, Canada.
    2,567
    Quote Originally Posted by thunderations View Post
    The last couple of choke cables I've purchased from flaps stores are pretty light duty, the last one is too wimpy to properly operate the choke on my truck so it may not operate in 'push' mode for the overdrive. I don't know how heavy-duty the overdrive cable needs to be as my car has been without an overdrive trans since the early 70's, but I do know the factory overdrive cable on my '54 coupe is way more robust compared to the flaps choke cables. BTW I decided the overdrive cable was too cool to remove from my car, so choke duty is now it's purpose. cheers, junior
    1954 C5 Hamilton car.
    14,141
    Truckguy, What's the part number for your truck. Not all cables were created equal.
    Most of the older farm equipment has heavy duty cables that can be used, if you don't care about originality.
    I know French Lake Auto Parts has several cars and pickups, and would have a cable for you, but I don't enjoy working in 0* weather for car parts.
    Oct 2010
    744
    I may have a cable I will check tomorrow , Ed
    Speedster Member bison's Avatar
    May 2009
    Hawthorne, CA, USA.
    159
    not sure , but i think i remember seeing an overdrive cable on 5 th ave. internet garage , along with other overdrive parts .
    Middle Tennessee
    1,563
    I have a factory underdash cable, but not the in dash one.
    1,205
    DSC07714.JPGDSC07715.JPGDSC07716.JPGI have three OD cables 62", 66" and 67"
    Skybolt
    Guest
    If long enough a hood release cable would work in a pinch.
    Len
    Oct 2010
    744
    Sorry I don't have one , Ed
    14,141
    Quote Originally Posted by bison View Post
    Yes; I believe Randy reproduces them.
    Feb 2015
    Cohasset, MN
    178
    Thank you everyone for your responses. I'll check 5th Ave Garage and then French Lake. If they don't have what I need I'll return here.
    Middle Tennessee
    1,563
    that 66" that Altair posted looks like it might work.
    Oct 2005
    St. Louis, Mo.
    1,629
    I have a bunch of NOS overdrive cables but they are all filed by part number
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
    Jul 2017
    Breezy Point, MN
    10
    I needed one for my '51 Ford and found that good reproductions are available. They say "OVERDRIVE" on the handle (which is better than a choke or hood cable), and since all of these cars used B/W overdrive units, if it's long enough, it should work. If it's too long, it's easy to shorten. Check the Ford parts suppliers. They aren't expensive, either.
    Winston-Salem, NC, USA.
    4,220
    36
    I have a lot of NOS cables for late '40s / early '50s. If you can provide the part number needed, I can check.
    Paul
    Winston-Salem, NC
