Results 1 to 3 of 3
Thread: Shock Absorber conversion
    Oct 2015
    Anchorage Alaska
    115
    I have Delco lever and Link shock absorbers on my 1949 2R5. Wanting to convert to a modern day shock because of leakage. Looking for info on shock mounts, mount locations, and shock absorber recommendations.
    1949 2r5 28196
    170ci 6cyl
    4spd
    6,061
    The front shocks mount to the frame right behind the radiator support and extend at about a 45 degree angle to the front axle. There are pretty good pictures of what the mounts look like in the 49-56 truck parts book. The problem is that the inner fenders were modified with a softball-sized dent to provide room for the upper shock mount.
    Champion Member sampsonka4's Avatar
    Aug 2018
    Austin, TX
    12
    Just curious if the OP found a solution? My 1950 2R5 has the same setup and I'm interested in doing the same conversion. Any learnings or help you can share would be greatly appreciated!
