Thread: Toe setting 85 Avanti
    Marysville, Washington, USA.
    553
    Cool Toe setting 85 Avanti
    I replaced a tie rod end, I'm not sure what the best toe setting is for my 85 Avanti. The car is a Touring Coupe with Western Wheels and 60 series BFG radials. I have set it at 1/8 toed in with the with the tires on turntables using a tape and my old racing toe set bars. Lou Cote
    711
    That'll work. A lot of guys recommend straight ahead with radial tires, but I think I like just a wee bit of toe in.
    President Member WCP's Avatar
    Feb 2008
    Glenburnie, Ontario, Canada.
    1,506
    Try 1/32" toe-in on each wheel for radials.
    Great Falls VA
    3,392
    You have to consider when the car gets moving and road force moving forward will splay the wheels, taking up wear in the other linkage joints. 0-3/16" is fine.
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Devon, Alberta, Canada.
    381
    I have tried with toe-in and with neutral. Definitely put some toe-in on the car or it will try to steer itself up every wear groove along most older hiways you drive down. A very nasty sensation when you are on a two way road with on coming traffic... In any of the northern states or Canadian provinces that allow studded tires the grooves and the wandering gets worse.
