Results 1 to 16 of 16
Thread: Ford 9 inch Vendor
    Fort Atkinson, WI, USA.
    650
    Ford 9 inch Vendor
    Does anyone know a vendor with a direct replacement Ford 9" for the Lark and C/K? I would like to avoid the drawing approval process.
    JK
    Sacramento, CA, USA.
    5,186
    The only Ford 9" I can think of that is a very close replacement width is the 57-59 Ford Ranchero. Maybe the wagon also? Maybe I don't have those years exactly, but it doesn't matter since they're rare as hen's teeth.
    But why not just go get one out of a Ford truck and have it shortened. I had mine done like that decades ago. Just find a local hot rodder who can point you to someone local who can do it for you. Lot's of guys do that sort of work. Its not that hard if you have the machines.
    sals54
    1,570
    You will most likely need to have a 9" Ford modified to fit. You might try an 8.8 or and 8" from a Ranger or Explorer. Later ones had disc brakes too. Somewhere I read that you use a 4WD rear with the offset differential and shorten the long tube and use another stock short axle, making the modification a little less expensive.
    Otherwise find a shop in your area and let them do the design and modification on a 9". All you need to do is supply the credit card.
    3,664
    The place for CASO's is Speedway. They have a Currie 9", 56" wide, with axles for about $600. Which is about $200 less than I can buy them from Currie and I have known the old man since the early 60's. All you have to do is weld on the locating saddles which cost about $20 at your nearest automotive swap meet. Or a few bucks more from Speedway. Weld them on at 41" apart.
    Feb 2012
    lafayette in
    4,409
    Isn't there a narrow 9" available from the Lincoln Versailles? Seems it may come with disc brakes too.
    1,570
    Yes, but like any desirable item from the late 70's, getting extremely rare and still not as narrow as needed for a Studebaker. We used them in Mustangs to get the 9" and disc brakes, but that was in the mid 80's when they were still available in junk yards.
    Quote Originally Posted by t walgamuth View Post
    650
    You guys are missing the point. I am aware of what can be made to fit and I am even capable of doing the modification. By the time I find a suitable assembly, cart it home, disassemble, clean, cut of the spring pads and ends, machine, buy new "late Ford big ends" & perches, weld and straighten it is more cost effective to buy a housing made to order. Art Morrison, Currie, Moser, etc. I thought if someone else had ordered one I could suck up some information. I have a housing from Art Morrison for the '53 project but it is set up for a four-link and the Lark will be on leafs. I will send an RFQ to Moser and see what they are compared to AM. AM is in Washington state and Moser is in Indiana so if the cost is close the shipping should be less. Thanks for the help and ideas.
    JK
    Mar 2013
    British Columbia & Arizona
    2,276
    I had one from a 55-57 T-bird which if I recall, measured perfectly. I know they are hard to find but maybe try someone like Amos Minter T-Birds as you never know.
    Good Luck,
    Bill
    3,664
    Actually, all Fords from 1957-59 had the same width rear at 57". The only difference was the bearings and brakes on the Bird and wagon.
    Sep 2007
    Hillsboro, Ohio, USA.
    1,300
    Moser Engineering in Indiana can make what ever size 9 inch you want .
    Randy Wilkin
    1946 M5 Streetrod
    Hillsboro,Ohio 45133
    Jan 2007
    waukesha, wisconsin, USA.
    381
    Quote Originally Posted by 3x2stude View Post
    JK
    I have copies of factory rear end drawings so if you want pertinent dimensions, I can supply them.
    james r pepper
    May 2012
    Oklahoma City
    638
    Looks like the 56 inch Currie at Speedway is up to $900 now: https://www.speedwaymotors.com/Curri...-Kit,8336.html
    They have an in house 9 inch housing and axles for $700: https://www.speedwaymotors.com/Speed...th,297525.html
    at least shipping is free.
    And with either, you still would need to buy the third member, brake set up and weld on axle perches.
    President Member WinM1895's Avatar
    Nov 2013
    Simi Valley CA
    853
    1977/80 Versailles have a 9" with disc brakes, as do 1975/78 Granada/Monarch w/351W
    1957/59 Ford passenger car 9's are the same width, the flanged axle shafts are right & left specific.
    F100/150 9 axle shafts are the same right and left, but are specific to certain years.
    1957/67 shafts have 28 splines, 1968/79 have either 28 or 31 splines, 1980/86 have 31 splines.
    The 8.8" integral was introduced in 1983, but the 9 was also available thru 1986. No F100's after 1983.
    Jun 2017
    Washington
    133
    Theres a 9" for sale on the Seattle craigslist for the early narrow 57 9". Its just the housing but axles can be cut and pumpkins can be found. I almost want to tell yoy to try a 8". Theyre rated for 300 hp and are as good as the 9". They weigh a lot less. And they will be similar in size due to being used on Falcons, Mustangs, and Comets rather full size stuff like Galaxies. I have one on my 65 Ranchero 200l6, works nicely.
    I didnt see what engine youre running but even if its a stock 259 or 289 or 170 l6, it should be fine
    Good luck,
    Ryan
    Mar 2017
    Green Bay WI
    44
    Ford 9" vendor
    Jon, not to confuse things but....I used Johns Industries / Caspian MI for my Austin Healey project. He has been doing 9 inchers for years, he may already have the data and-or add Jims dimensional data for your needs. He is near us (in the UP by Iron Mtn.) and is reasonable on pricing, you can go from basics to full wild....just add money. Regards Sherm / Green Bay
    Oct 2010
    Blairsville, GA
    783
    I still have my dad's last Studebaker, a Daytona Cruiser. He put a nine inch Ford rear end in it about forty years ago. He said it fit right in.
