![Embarrassment](https://forum.studebakerdriversclub.com/core/images/smilies/blush.gif)
removing starter from'63 Lark 6cylinder
Finaly getting around to replacing the clutch in my '63 Lark 6cylinder stick with od. Unbolted the starter, very tight place. I can only move the starter a very short distance foreward to clear the bell housing. Problem is, the starter hits the distributor, just seems to be to tight to move the starter foreward. Do I have to remove the distributor for clearance as there just seems to be no room to remove the starter. Thanks, Arnie
Tags: None
You shouldn't have to. Is the one bolt causing you to move it so far forward? Once you clear that bolt, you can easily move it around and get it out of there, but pushing that bolt to the rear should make this possible.Ron Dame
'63 Champ
