Results 1 to 15 of 15
Thread: Lark Map Light is broken
    Apr 2017
    252
    While trying to replace the bulb in my 59 Lark dome/map light, it appears that the bulb backing piece has broken.
    Do I need to replace the whole unit, or is there a fix for this?
    I guess I could try to make a replacement piece out of plastic, not sure how well that will go...
    Any suggestions?
    South hills, Pa, .
    603
    Dorman has one found at Rockauto should be able at any auto parts store
    http://www.rockauto.com/en/moreinfo....599409&jsn=292
    4,839
    In a pinch I've even made such a piece from an old circuit board after I removed the copper.
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    2,080
    That interchanges with many other years. I'd replace it so it does not sort out down the road.
    Apr 2017
    252
    Look what I found at Autozone. Sweet!
    10,421
    Quote Originally Posted by creegster View Post
    Unless I'm missing something, you need to take that one back and exchange it for a "single" filament bulb. The one you show here looks perfect for a double element bulb, but not a map/dome light.
    1,641
    The broken one in the original post is a dual contact insulator. Had me puzzled too, but it has 2 contact holes but only one wire and contact.
    Apr 2017
    252
    Quote Originally Posted by thunderations View Post
    This looks right to me: the original was a double-filament as well. IE, it has 2 contacts on the base of the bulb. Some parts shot out of the housing when I was working on it, and I dont know where they went, so they are not in the original photo.
    1,641
    The bulb may use one filament for the switched power at the light housing and the other filament for the door switches.
    4,839
    Double contacts does seem strange, and I'd look at the wiring schematic to see what they show.
    Aug 2005
    , , Canada.
    15,880
    As per the Owner's Guide, they use a 1004 bulb, which is double-filament. https://www.autozone.com/electrical-.../16805_0_18269
    10,421
    Quote Originally Posted by 8E45E View Post
    Thanks for the clarification...a good thing to remember...'till I forget...again
    Montpelier, VT, USA.
    1,166
    There was a time when you would see scads of these late model "used" dome lights, including the cover and lens, for a buck or two at Studebaker swap meets.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    1,227
    There are single filament with dual contact bulbs for a variety of applications where the assembly is not used as a ground where one of the wires is connected to ground. I have wired some lighting this way to assure a good ground. This type of assembly is used in marine applications where the body is fiberglass where there is no continuous ground. This also works well around rusty tail lights and anywhere where a good grounds are questionable.
    Aug 2010
    2,080
    Studebaker actually sold those 'fiber discs' as a repair item. We have a bin tray full of single wire types.... Not sure If we have a disc for two wires or how many.
    Anyone need single wire discs?
    Now days a good dome assy is 20 bucks in good condition. (evil vendors! )
    https://www.ebay.com/itm/30263274838...84.m1558.l2649
