So, I bought a complete running 57 Packard Clipper with the supercharged 289. Planning to transfer as much as possible to my 53 Hardtop Commander, engine, trans, rear, possibly the frame and suspension, and the brakes. Because the tank is so rusted, it only runs on a gas can with with a makeshift electric fuel pump bypassing the mechanical pump.
I would like to get it running on the mechanical pump. I have read that the supercharged engines use a special pump that increases pressure with the boost.
Am posting a pic of the current mechanical pump. Also, I found this on ebay: https://www.ebay.com/itm/1957-1959-P...53.m1438.l2649
Does the pump I picutured look like an original? Seems to match the one in the ebay auction.
I do not see a port for a vac hose on my pump or on the ebay pump.
If this pump really does increase fuel pressure under boost, where does it get the signal?
Then and Now has a rebuild kit, which I can purchase and install on my original pump. I know I have to remove it and get numbers for them before ordering.
In the alternative, I have read that the R2 pump is a good upgrade, and will combat vapor lock. I understand the frame on my 57 Packard (which may end up under my 53) would have to be notched. I also read that it has a return line. Does that mean I will need to modify my 53 tank (it is in better shape than the 57) to accept a return line if I go that way? Is the R2 upgrade really worth doing? I doubt I will ever drive the finished car across the desert. However, we do exceed 100 F. regularly in the summer here in central OK.
Sorry for so many questions.
