Need a brake pedal assy for Auto trans 1957 Golden Hawk
  • Need a brake pedal assy for Auto trans 1957 Golden Hawk
    I need the whole works if you have it. I am converting a stick shift Hawk back to automatic and I need the brake pedal/ arm/ assembly for one, it does not have power brakes..... Thanks
    FWIW, I modified the Stock brake peddle/clutch peddle assembly on my Sky Hawk, then added an automatic peddle pad. It was not a difficult procedure...
      Mike:
      What are you doing with the removed stick shift parts? I may be interested.
      Thanks Howard.
      Howard - Los Angeles chapter SDC
      '58 Packard Hawk. A partially restored car that was not completely assembled.
Name:	57 G hawk during 003.jpg
ID:	1718017Still trying to ID what may have been changed on the car, but I suspect during the 'conversion' the wrong one was used, or maybe the car had power brakes, but then they were changed. The car just does not stop like it should. Waiting on the build sheet..... Not sure what is happening with any spare parts, but its only a T 86 OD .
          Mike,
          Check with Tom K in South Bend. He use to have "several" 55 gallon drums full if pedals.
          Jim
          their Memorials!
            Nothin' wrong with a T86. I still might be interested.
