The Town Cars only had rear axle Air Bag suspension. Continental had all 4 corner air bags. Easy fix if they are bad. Go to junkyard, get steel coils and hardware from Crown Vic or Grand Marquis
95 Lincoln Town Car
Or get some of the readily available bladders and enjoy the ride the way it was intended. I drive TBirds with springs, and a Mark VIII with air suspension, and there really is a difference. The bladders are no harder to replace. then replacing them with springs.
Well, I wound up getting this car, and it was a mistake for sure. The engine is kaput. Left bank, 1,2,3,4, 40, 75, 65, 45 psi compression. Right bank, 5,6,7,8, 0,0,0, 10 psi. Pulled off the RH cam cover, timing mark on cam appears to be where it is supposed to be when the crank is at TDC mark. Hooked air compressor to right bank cylinders: 5,6,8 have air blowing past intake valve; #7 has huge leak into crankcase, so hole in piston. I did rotate the engine to ensure the valves were both closed on each cylinder under leakdown check.
I don't think it's worth my while to put an engine in it, unless I can get an engine for almost nothing. I will probably part it out. Anybody need anything?Gord Richmond, within Weasel range of the Alberta Badlands
What do the wheels look like? A lot of people use Crown Vic wheels on Studes, and the Town Car is basically the same platform, right? Will they fit a Stude and look decent?
Let me be clear, I don't need them.......and they are too far from North Carolina to ship. Just wondering if they might work and look decent on a Stude.Paul
Winston-Salem, NC
Originally posted by gordr View PostI just got offered what looks like a screaming deal on one. Body sound, interior clean, shows a little wear, good rubber. Apparently needs a crank position sensor to make it run. This is a 4.6 liter OHC V8. I don't know diddly squat about them. Looks like it would make a darn fine driver if the engine could be made to run.
Anyone here got some knowledge?
Who stated that it only needs a crank position sensor? You may have recourse there and be able to get the deal reversed.Gary L.
Well, I bought it as a non-runner. It may well have thrown a code for that, too. I will tell the seller what I found; if he wants to adjust the deal, fine. If not, well, it's caveat emptor. Poking around the PHX Craigslist, it looks like parting it out might come close to breaking me even.
Paul, the wheels spoked aluminum, many thin spokes, with good tires. Should try them on the Lark, which is parked right behind the Lincoln, right now.Gord Richmond, within Weasel range of the Alberta Badlands
I would load your Suburban with all the rust-free body panels and haul them back to Alberta. List them on Kijiji as there would be a better market for them here. https://www.kijiji.ca/b-alberta/1995...0l9003?dc=true
I may be wrong, but the subframe that the front suspension is mounted to should be the same as a Crown Vic and those are popular with the truck modifiers as they bolt straight on F series trucks from the 60's on up with only a few brackets added to the F series frame.
Originally posted by spokejr View PostI may be wrong, but the subframe that the front suspension is mounted to should be the same as a Crown Vic and those are popular with the truck modifiers as they bolt straight on F series trucks from the 60's on up with only a few brackets added to the F series frame.
1979/2002's have worm and roller P/S; 2003/12's have rack & pinion P/S
The last years of the Crown Vic's were sold as fleet vehicles, cop cars and taxi-cabs.
The front suspension/steering is a popular swap for 1961 and later F Series (F100/350) trucks.
Originally posted by gordr View PostWell, I wound up getting this car, and it was a mistake for sure. The engine is kaput. Left bank, 1,2,3,4, 40, 75, 65, 45 psi compression. Right bank, 5,6,7,8, 0,0,0, 10 psi. Pulled off the RH cam cover, timing mark on cam appears to be where it is supposed to be when the crank is at TDC mark. Hooked air compressor to right bank cylinders: 5,6,8 have air blowing past intake valve; #7 has huge leak into crankcase, so hole in piston. I did rotate the engine to ensure the valves were both closed on each cylinder under leakdown check.
Originally posted by 8E45E View PostI would load your Suburban with all the rust-free body panels and haul them back to Alberta. List them on Kijiji as there would be a better market for them here. https://www.kijiji.ca/b-alberta/1995...0l9003?dc=true
Craigsigpic
1954 C5 Hamilton car.
I don't know if the car is importable to Canada, but I expect it is, since more than 15 years old. But it would have to come up on a future trip, since my trailer is at home. The wheels on this car are the same as depicted near the bottom of the Kijiji page on your link. I think I will put it up on Craigslist here, and see what happens. I don't want to waste too much time here parting it out.
It occurs to me that the multiport injection on this engine might be transplantable to a Studebaker block. The heads are made with their port faces perfectly horizontal, and the aluminum manifold just plops down on top of them. A pair of wedge-shaped adaptors could be made to bolt to Stude V8 heads to mimic that setup. Provided that the relative dimensions permit. I won't let this car go to the scrapper without having picked its bones clean for what I might want, if parts sales prove hopeless.Gord Richmond, within Weasel range of the Alberta Badlands
It is on the wrong side of the country for you, but I just noticed an interesting current auction. It is the Sachem auction under www.AARauction.com
It includes two lots, each lot consisting of a rebuilt Ford 4.6 litre V8. They are both long blocks still sealed in their "crates"/boxes. One is a '92-'94 and the other is a '95.
The current bid on each is $70.Gary L.
