Results 1 to 9 of 9
Thread: 64 Avanti Battery Drain
    Jul 2013
    Yorktown, Va
    55
    Have had difficulty with battery drain in my 64 Avanti R1. After sitting a long time, battery is dead with no switches or lights having been left on. (It had also set in the garage with temperatures freezing and snow outside.) Performed an amps test between battery positive terminal and positive lead going to rest of car. On the 250 milliamps setting, it reads 50 milliamps with the battery fully charged and nothing switched on. Is this normal? I do have a brand new battery in the car now which cranks and starts fine. Is there something draining or is the 50 milliamps draw normal?
    3,675
    Your clock can draw that much.
    4,875
    Do you have a modern radio in the car? The "keep alive" connection for the push button memory draws enough to drain the battery.
    Jul 2013
    Yorktown, Va
    55
    Yes, I do, RadioRoy. Didn't know it would drain that much, though. I have a modern radio in my '65 Mustang also and haven't had battery issues to this extent. But I hear what you say, thanks for the tip!
    Frederick, Maryland, USA.
    4,144
    How long is "a long time"? If the battery was iffy to begin with it could just be nature taking its course. Modern cars that are rolling computers will drain a full and strong battery within about a month if left to sit.
    4,875
    Quote Originally Posted by Ted Johnson View Post
    I put a modern radio in my 54 and the battery was dead in a week or two. Guess I need to build one of my own radios for it.
    Great Falls VA
    3,392
    It's the clock....
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Jun 2008
    Saugerties, NY, USA.
    81
    Ted Johnson;
    The clock (unless it has been changed) would be a intermittent draw. Each time the clock is wound. The memory radio would be a steady draw. With nothing on; in a regular Avanti the only thing drawing current should be the clock. A good reason to disconnect the battery when the car is parked. Safer that way.
    On my 95 Chevy diesel truck I had to remove the fuse from the radios memory; could not hear the radio anyway once the engine was running. The radio still worked; just had to retune it every time, if I wanted to listen to it.
    Ron
    21,390
    If your battery is good, the clock should not draw it down in a week unless the clock is not the original type or the points are stuck resulting in a steady drain.
    I just noticed that you said; "a long time". I do not know how long that is. If it is more than a week or two, a lot of things, including the clock, may draw the battery down.
    I know of people with show cars who installed a small toggle switch hidden under the dash to disconnect power from the clock when they will not be using the car.
    If you are going to leave the car sit unused for weeks, I would suggest either disconnecting the battery or using a good battery maintainer on it.
