Dad's 50 Champion needs a new axle shaft. I called Barry Hackney and he didn't think he had any. Just trying to avoid spending a day on the phone blindly calling various vendors. If anyone knows a vendor that typically has axle shafts, it might save me a bunch of time.
Most Likely Vendor to Have Axle Shaft
Tags: None
Wayne, a long shot, but you may want to check with David Hauser in Clemmons NC. He probably would not have a new one, but may have a used rear end removed from a car sometime in the past.
For what it's worth, the part number is 521594 and is listed for 1947 thru 1950 Champions.Paul
Winston-Salem, NC
Studebakers West usually has them. They are the second largest parts dealer.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Looks like I am going to be waiting for Stephen Allen's to get their re-pops done. None of the sources suggested have one of these axles.
It seems that Champions of this vintage all need axle shafts and the idler arm assembly in the steering. Finally found the idler arm and bought the last one they had. Looks like the axle shaft is going to be just as much of a search.Wayne
"Trying to shed my CASO ways"
For those who have had axles fail on these early postwar Champions - what is the predominant failure mode?Paul
Winston-Salem, NC
It would be extremely rare for a Six Cylinder to have enough Power to actually Hurt anything inside the "Pumpkin".
The "Usual" failure would be the Axle Keyway from greasing it or the Hub, wrong installation of the Key, loose or not enough Torque on the Axle Nut, leaking Seal and no Lube etc. Not really failures, just dumb mistakes.
That is of course, assuming someone did not install a Torquey Studebaker V8!StudeRich
There is a very good chance I have one or 2 or 4. I don't have parts id for everything but a photo of your old one and length.
rillerich@gmail.com
hadleyrille, e-mail sent. Part Number is 521594, if that is helpful.
As for failure mode, the threaded end collapsed under the pressure of the hub puller. Yes we had the nut installed when pulling. The hole for the Cotter pin is closed up and the last 3/8" of thread is all screwed up, as well as the threads of the nut. The strange thing was it had only been about a year since the last time we had the hub off.
I am liking the flanged axles I installed on my Hawk more and more.Wayne
Originally posted by wdills View Posthadleyrille, e-mail sent. Part Number is 521594, if that is helpful.
I am liking the flanged axles I installed on my Hawk more and more.Paul
Winston-Salem, NC
