Results 1 to 8 of 8
Thread: Housing Width?
    Fort Atkinson, WI, USA.
    639
    Housing Width?
    Is a 65 - 66 Commander rear axle housing the same width as a C/K body? Spring mounts the same?
    JK
    5,738
    Yes. The only differences is the lengths from the centerline of the axles to the yoke, between the model 44, and the model 27. The Dana 44 is larger, and requires a shorter driveshaft if you are upgrading from a smaller model 27.
    639
    Sweet, looking at buying two '65s so the rear assembly is desirable with the flanged axles.
    JK
    2,798
    Only late 1965's have flanged axles
    639
    Can you tell by body number?
    JK
    28,773
    Almost NO info can be found with the Body Number since it is NOT the Car, only the sequential Body Line Number on the BODY line and the Year and Model Number you already know.
    The Car Serial Number often is a clue, IF the changeover Car Number is known.
    In this case, just remove a rear Hub Cap or Wheel Cover and look for the Axle end and Nut found on Tapered Axles, if none it's a Flanged Type.
    639
    I meant the serial number. I will see when I go to look at the cars this weekend.
    JK
    Jan 2007
    waukesha, wisconsin, USA.
    419
    Both the model 27 and model 44 use the same 27 or 28 spline flanged axles. Six cylinder cars had a Dana 27 and 283 cars a 44. The flanged axles are trouble free untill you make some real power and add good tires. They can be twisted off with some effort. Don't ask how I know this.
    james r pepper
