Can anybody recommend an air horn for my Champ that actually sounds like a big rig or locomotive?
air horn recommendations?
1963 Champ "Stu Bludebaker"- sometimes driver
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1941 Commander Land Cruiser "Ursula"- basket caseTags: None
In the 70's I found a set of vacuum horns, which I installed on my Corvair. They are very loud, just like semi truck air horns. I haven't seen any since then. They are the same size as air horns, but don't require any compressor. I just ran a vacuum hose to the engine and plumbed in a vacuum solenoid off some 70's GM car, then wired the solenoid wire to the horn relay.
I bought some air horns on ebay for my GMC Duramax brand new, removed from a GM Topkick. IIRC, they were about $30 usd a couple of years ago. I saw lots to choose from, but if you are getting real big rig style horns you will need an on board compressor and tank, they require lots of pressure and cfm.
