Results 1 to 10 of 10
Thread: 1959 Dash in a 1962?
    President Member irish's Avatar
    Aug 2009
    Owasso, OK USA
    611
    Curious, will a 1959 Lark dash fit in a 1962 Lark without any modifications? I'm not concerned with every bolt hole lining up, but is the contour of the dash the same?
    Joe
    1962 Daytona
    1964 Cruiser
    And a few others
    Winston-Salem, NC, USA.
    4,220
    36
    Joe, I haven't tried this, but I would think it would be really close. [WRONG - see below comments! ] They both had deep wrap-around windshields although the '59 doesn't interchange with the '62 (and vice versa).
    Not that it matters in this discussion, but Jim Geary put a '55 Ultra Vista dashboard into a Champ pickup many years ago. It looked really neat.
    Last edited by r1lark; 01-06-2018 at 09:10 PM. Reason: made correction based on next two posts...
    Paul
    Winston-Salem, NC
    Mar 2017
    Parkton, MD
    169
    No, the crown of the cowl was reduced after 1960, and the curve of the windshield at the outer edges was greatly altered.
    28,773
    A '55 in a '60 would be no big deal at all, and '56 to '58's are a bolt-into a '60, but a '60 into a '62 would definitely be a very poor fit without serious alterations.
    Austin, Texas
    982
    Quote Originally Posted by irish View Post
    Joe
    I did the opposite fitting a '62 dash into a '64 T-cab. No, it's not a direct fit but doable. For the upper, (dash pad area), I spliced the '62 to the '59 base with pop rivets then removed the assembly and welded it as a unit. (You have to use pieces of both given that the windshield curve is different)
    As an aside, I think the 1961/62 dashes were the best of the Lark series especially when you used gauge clusters from 1963 up...
    Jun 2017
    Washington
    133
    Do the dashes in these cars really just unbolt? My 61 Lark needs the white spaces repainted, and i thought itd be easier to pull it out rather doing it in car.
    Thanks,
    Ryan
    Dec 2007
    Union, CT., USA.
    4,433
    Yes they do.
    Quote Originally Posted by StarDiero75 View Post
    Thanks,
    Ryan
    Joseph R. Zeiger
    Apr 2008
    Seligman, Az USA.
    5,062
    Thanks,
    Ryan
    The only thing that makes this more work is the wiring since by this time most others went to a printed circuit board & simplified wiring alot while Studebaker still wired everything separate. I started to play with a 62 dash into a 60 Lark cowl section & found it wasn't a direct bolt in fit & stopped.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
    Jun 2017
    Washington
    133
    Quote Originally Posted by Warren Webb View Post
    Yeah ive noticed that when comparing the Lark to my 65 Ranchero. I almost kind of like the straight wire, i thinks its not as hard to figure out crazy crap rather than with the circuit boards. But hey, im 19, what do i know?
    Aug 2009
    Owasso, OK USA
    611
    I knew the windshields were different in the 62's compared to the 59's so the dash being different wasn't a surprise.
    1962 Daytona
    1964 Cruiser
    And a few others
