Hi All-
I was going to make a post requesting information as to the colours & hue I should repaint the engine of my 1962 GT Hawk, but on checking the engine number I thought that I ought to request some clarification on that as well.
The stamping shows P I 0 2 3 8 4 (that is definitely an 'I' not a '1').
Checking skip Lackie's Engine no. page (http://www.studebakerdriversclub.com/V8EngineID.asp) it would appear that this is a 1963 engine transplant? The 'I' is September, but I'm not sure I am interpreting the rest correctly . BTW, this is an Australian delivery car in RH drive
Back to painting- the block should be black I believe but is there a recommended hue, like flat, semigloss.....? Rocker covers Yellow, check. But what about the inlet, exhaust and water pump manifolds?
Right now, I'm getting off as much of this infernal Chevy orange (and even yellow) as I can- the 289 might resemble a big block Chev, but it aint!
The engine has just had a replacement sump (Rusted out, believe it !? ), crank and sump seals all around
Thanks, Steve.
Thanks, Steve.
