Results 1 to 16 of 16
Thread: Thrust block stuck backwards
    Feb 2006
    Asheville, NC
    1,522
    Dana 44 twin trac. I pulled the axles to repack the bearings, possibly for the first time ever from what I see, and of course one of the thrust blocks falls out. It's backwards, and I can't get it out or to flip to the correct direction. I used my magnet on a stick thing, and the POS fell apart, leaving the magnet somewhere in there too. I can't seem to get the thrust block out so I can turn it and reinstall it, nor can I find that magnet. Without tearing the whole diff apart, does anyone have any ideas how to get teh thrust block and magnet out?
    Ron Dame
    '63 Champ
    5,320
    Find a dowel or broomstick that will fit in there, and epoxy a dime-size rare-earth magnet to the end. Let the epoxy set up real well before using that tool to fish for the lost lambs.
    Feb 2006
    Asheville, NC
    1,522
    it seems the magnet on the dowel isn't as strong as the one lost when first retrieving the button
    Ron Dame
    '63 Champ
    27,877
    If the lost Magnet is pretty strong, it very well may be stuck to the inside of the Axle Tube, so you will have to knock it off with your broomstick first.
    Feb 2006
    Asheville, NC
    1,522
    I'm afraid the magnet may be inside the chunk, I can't see it looking down the tube. And I think it may be holding the thrust block in place, so that I can't get it back out.
    How horrible a job is it to remove the chunk with the axle in the car? Will I need any of the special tools to remove and replace?
    Ron Dame
    '63 Champ
    17,827
    Take it over to any decent 4wd shop. They work on Dana 44's all the time and have you fixed up in a couple of hours.
    The forum isn't going to fix your problem....
    There is a case spreader tool made that will assist in the removal and reinstallation of your carrier.
    But the cost of the tool will be more than having a shop pop out your carrier, grab the loose pieces, and put it back in.
    Since you are not changing any settings, no readjustment is needed (unless your tooth pattern shows something irregular.
    Quote Originally Posted by Ron Dame View Post
    Feb 2008
    Wimauma, FL, USA.
    720
    If you can turn the pinion, it is easy to remove the carrier. Drain it, remove the cover, and axles, remove the 4 bolts that attach the carrier. Now all you need to do is to place a shop rag between the ring and pinion teeth and turn the pinion. The carrier will back right out. To re-install, just use a dead blow hammer to seat in place, and reverse the removal process.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
    Feb 2006
    Asheville, NC
    1,522
    Quote Originally Posted by 64studeavanti View Post
    I tried this method, and it worked for me! Actually, I did not fully remove the carrier, (Spare tire recess kept it from moving further) but when about 1/2 of the splined hole was visible, I was able to reach in with a roach clip and remove the magnet and replace the pin.
    Thank you everyone!
    Ron Dame
    '63 Champ
    4,546
    Haven't heard anybody call it a roach clip in maybe 40 years.
    Feb 2006
    Asheville, NC
    1,522
    Well I forgot what it's really called. It has been remanded to the tool box.
    5,595
    Some people call it an alligator clip.....just sayin'
    Apr 2006
    Union Gap, Washington, USA.
    598
    I would also try a long piece of PVC tubeing attached to your shop vac to tyr ans suck the magnet and rubbing block out.
    65 2dr sedan
    64 2dr sedan (Pinkie)
    61 V8 Tcab
    63 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
    45 Agricat
    67 Triumph T100
    66 Bultaco Matadore
    Apr 2006
    St. Louis, MO, .
    1,871
    Must be some pretty tiny alligators?
    Feb 2006
    Asheville, NC
    1,522
    Quote Originally Posted by skyway View Post
    Guess so. BTW, do you know the easy way to tell and alligator from a crocodile? One will see you later, the other will see you in a while.
    Ron Dame
    '63 Champ
    Great Falls, Montana, USA.
    695
    Boo-hiss...thats awful.
    Feb 2006
    Asheville, NC
    1,522
    Quote Originally Posted by E. Davis View Post
    Thank you!
    Ron Dame
    '63 Champ
