Searched the forum and could not find the answer. What is the correct engine colors on the 53 Commander 232? I am dropping a 289 in it but am trying to keep it looking correct. I have seen black, turquoise, orange........Do valve covers stay yellow? Color of Dg200 trans?
Correct engine color
Studebaker Olive Green on everything Fan to Tail of Trans. They did have the Black 4 Bolt Valve Covers and Oil Filler Pipe with the Fuel Pump on the side of it, but I would not quite go there.
Here's the correct Olive Color on a Six, it was used on all from '47 to '54.
Most of the C & K Models you see, do not have their Original 232's so are various Colors from newer Models.Last edited by StudeRich; 11-17-2017, 06:15 PM.StudeRich
Originally posted by StudeRich View PostStudebaker Olive Green on everything Fan to Tail of Trans. They did have the Black 4 Bolt Valve Covers and Oil Filler Pipe with the Fuel Pump on the side of it.Last edited by bensherb; 11-18-2017, 01:12 AM.
Originally posted by tim333 View PostRich, your 1st photo example seems to show the fuel pump green also. True?
Then again it depends on whether you have a High Mounted '51-'54 V8 Pump, a Low mounted '55-'64 V8 Pump or a Six as to HOW much paint hit it!
The bottom line is; they did not intentionally Paint it, if the year model dictated for it to be installed at Paint time, it got some overspray.
Here is an ORIGINAL '57 Commander Engine, but it has a Bare, Aftermarket replacement Airtex Fuel pump. You can see how they slightly oversprayed the Valve Cover, even though it had a "Cover" over it.
Here they are on the engine Line, running in New Engines and doing the Hot and Running Valve adjustments with the cut away Valve Covers in place, connected to Water, Fuel and the Exhaust exit system even a Temporary Air Cleaner probably not so much to keep the Engine Clean, but to keep trash like Bolts & Nuts OUT!
These are 1955 to 1957's so one might be yours Tim!
Thanks to Richard Quinn, of course!Last edited by StudeRich; 11-18-2017, 09:10 PM.StudeRich
Originally posted by lelshaddai View PostGreat information. Is there a Krylon, Rust o leum paint name equivalent that matches the color?"In the heart of Arkansas."
Originally posted by skyway View PostBought a really good match once at a model train store; can was marked "Olive Green."
Also, not to be a broken record, but the old Bell (telephone) System green is also correct.StudeRich
