I am a retired insurance claims adjuster and have written many auto collision estimates in my life. I thought I knew nearly all the terms but some terms start out as regional or else are specific to one car company and I never did learn them all. With that in mind, please tell me what an A pillar is. Is it the hinge pillar or the lock pillar? Thanks!
A Pillar
Small disagreement. B Pillar is rear of front door latch point. Not always called a pillar if it does not reach the roof line- Think hardtop. C pillar is at the back of a hardtop or sedan roof leading down to rear quarter. D pillar only station wagons at rear of roof. So you may have A-B-C pillars most 2dr, 4dr, club coupe etc, A-C pillars hardtops or business coupes/ 3 window bodies/ GM mid 70's colonade designs etc, or on wagons A-B-C-D OR A-C-D pillars on 2/4 dr hardtop wagons.
Think I am pillared out.
Best I understand use of the A-B-C-D pillar references, your knowledge may differ.
SK
A Pillar is the windshield pillar, B Pillar is either the lock Pillar (2 door) or center Pillar (4 door) C Pillar is the lock Pillar on a 4 door In todays world, you usually have to buy a "uni-side" which is all of the above! No matter which portion of it you need. There are some vehicles that is is NOT recommended to section any part of the uni-side.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Jim What is recommended and what gets done in the real world are most times two different things. In my 45 years of doing body work you would not believe some of the things I have seen done. May have even been a party to some of it because that's what the owner wanted done. Back when I started doing body work most estimates where wrote as Hinge pillar, windshield pillar, Lock or door pillar, And what is now called a C pillar was know as the sail pillar or panel. No matter what anyone calls them still the same thing and do the same job. So guy's you can call it what ever you want as long as someone else understands what your talking about.
As Skip and Jim indicated, regardless of where the hinges and latches are located, A, B and C pillars will be universally front, center and rear. I've also seen "sail panel" as referencing something more than just the C pillar.Brad Johnson,
'56 Sky Hawk in process
