Results 1 to 3 of 3
Thread: 57 Golden Hawk Fuel Pump
    Commander Member
    Sep 2016
    NORTH CAROLINA
    54
    Well, we tried to start up the beast, and the fuel pump is no longer working. It worked during our Mock-up phase. So I ordered a rebuild kit and have found out that the pump is an aftermarket one and the rebuild kit is for the original Carter. Does anybody have one lying around? We have the rebuild kit, so it doesn't have to be in good working order. Thanks, John
    Nov 2004
    , , Canada.
    876
    The original pump should be pressurized,if still supercharged.If I wear U I would go with a electric unit lots of pressure for S/C & no problems.You could always leave original o just not in use.
    Commander Member
    Sep 2016
    NORTH CAROLINA
    54
    WoooWooo! Already found one, and it's FREE! Thank you, sir, may I have another?
