Results 1 to 24 of 24
Thread: 4 SPD Lark
    Oct 2016
    southern ca
    330
    4 SPD Lark
    Just curious ..What was the first year for a factory 4 speed lark?
    Mar 2011
    Damascus, OR
    1,554
    1962.............
    27,715
    FYI: Chevrolet had the Borg Warner T-10 4 Speed in 1961, and Ford had them in 1962.
    This Ford Case availability allowed the '63 and '64 Studes. to use the Standard Stude. 3 Speed Clutch Housing that Studebaker Cast to mount it, instead of the weird, "Special" Chevy Case bolt pattern Clutch Housing that HAD to be used on '61 Hawks & All '62's.
    Oct 2016
    southern ca
    330
    Hey Rich , I understand the different bellhousing patterns on the Stude 4 spds, But didn't chevy start using the T10 on the 57 Vettes?
    27,715
    Maybe so, I only know about CARS! As in Impala SS 409's, BelAires etc.!
    Bellingham, WA, USA.
    14,029
    1959 Chevrolet passenger cars had an optional T10 4 speed...
    http://www.348-409.com/1959factpage.html
    Dick Steinkamp
    Bellingham, WA
    Jun 2010
    1,391
    Here is a build sheet for a 62 Daytona 4 Speed.
    Ocala, FL
    65
    From what I've read, 1961 was the first 4-speed Lark. Never seen one, though.
    20,395
    Quote Originally Posted by wwogg View Post
    Available on 1961 Hawk, not Lark.
    Ocala, FL
    65
    My mistake, studegary. You are absolutely right.
    Oct 2016
    southern ca
    330
    Well heck....there goes my plan of passing off the 59 as a rare factory 4spd
    Oct 2017
    Wooster,Ohio
    19
    Very timely thread! I just bought a '60 Lark, 259, 3 speed T86 E-1T stick shift trans; Will any of the later Stude 4 speeds be a direct bolt in with my clutch & bell housing? If so, what years & models? I would really like a 4 speed! Thanks in advance! DAN
    Oct 2016
    southern ca
    330
    Mine's got a chevy in it but theres lots of guys on here that can answer your question
    Oct 2017
    Wooster,Ohio
    19
    What trans did you use, Lumpy?
    Oct 2016
    southern ca
    330
    I used a muncie m20 but you will need something more stude specific. I probably should have been more clear, My lark has a 327 chevy engine in it. Hoping StudeRich will chime in he's a wealth of stude interchange info
    27,715
    Quote Originally Posted by ratfink396 View Post
    You need a '63 or '64 Hawk or Lark Type, Borg Warner T-10 4 Speed, and it WILL Bolt up to your Clutch Housing.
    A '61 or '62 Stude. T-10 has a Chevy pattern case and will not fit, but the '63-'64 has a Ford Case and will fit.
    The Input shafts and many other parts on Chev./MoPar/Ford T-10's will not fit.
    Many people find that the T-86 WITH Overdrive also fits, and CAN BE a better Combo for "Cruising the Interstates" than a Direct 4 Speed.
    Oct 2010
    672
    There have been some T-10's backed up with O.D. , I think Jim Geary did this , Ed
    Oct 2016
    southern ca
    330
    I'm pretty sure gear vendors also makes an OD for a BW . Just depends on what you want for your application ,gear ratio etc. If you do lots of highway cruising OD is a great way to go. If you enjoy spirited in town driving..or the occasional run down the 1/4 mile ,give me a 4spd Two of my cars have Tremec TKO 600 5spd's in em and they work really well. The lark has a high winding 327 sbc and a muncie 4spd with 4.11s . Drove it for the first time yesterday and again after work today...Still grinning from ear to ear! Although I did toss the alt belt at 6500 rpm, Just ordered a deep groove pulley from Summit!
    14,029
    The hot set up to have both a 4 speed and OD (at least for a Chevy), is a Saginaw 4 speed with the OD from a Saginaw 3 speed. Pretty much a bolt on.
    http://www.chevytrucks.org/tech/overdrive.htm
    Dick Steinkamp
    Bellingham, WA
    Oct 2017
    Wooster,Ohio
    19
    thanks all for the input! I think the direction wanna go is in the 63-64 Stude 4spd. Any info on what to expect with a driveshaft? my current 3spd has what I would describe as a long, skinny tailshaft that I'm not seeing much reference to & looks longer than a lot of the pics I'm finding in my research of stick shift cars. Trying to get an education & gather parts over the impending winter! THANKS AGAIN! Dan
    Jun 2010
    1,391
    4 Speed transmissions are shorter, so the shaft will need t be longer, as well as the Auto had fine spline, 4 speed more coarse spline.
    The lengths are in the parts manual.
    Oct 2017
    Wooster,Ohio
    19
    Good info! Thank you so much!😉
    Silver Hawk Member JRoberts's Avatar
    Fayetteville, NC, .
    9,122
    I am glad the T-5 tranny was mentioned. That seems like a very viable option.
    Mar 2008
    Parkersburg, WV, .
    226
    I decided to go with the T-5 from a V-8 Mustang.Same spline count as Stude.I think Fairbon Stude sell the adaptor kit.
