Hi,
putting together the kingpins for my '57 Golden Hawk; have NOS king pins, and NORS (old NAPA) bearing/bushing set, with a newer, fresher cork gasket set in a separate box within the NAPA box. (MY assumption is they are newer, as they'd be pretty stiff if they were as old as the NAPA box, and doubt they'd be in a separate box). Regardless, see photo below; I pressed my new bearings in to ~1/16" as recommended in a post I found from a few years ago, to "accommodate a cork gasket". But this seems pretty high! How much should they stick up from 'flush', for "crush"?
I've seen recommendations for using an O-ring instead, but never an exact size for one (and siping/cutting into rubber as also recommended, for greasing, also seems prone to a propogating tear, into a split O-ring; though if this cork gets crushed too much IT will crumble and not be such a good situation either! ;-)
Anyway, whether cork or O-ring, how much should stick up from flush with knuckle? Thanks!
Barry
Barry
