i need to move a '63 avanti 300 miles. i have both a trailer and a car dolly. the dolly is much easier to deal with but i don't know if towing with the back wheels on the ground WITHOUT removing the drive shaft will hurt the powerflight. flat towed many cars years ago with no problems but never a studebaker. i'm looking for cold facts here, not an opinion, so if anyone can help i would appreciate it. thank you.
towing
Tags: None
You should disconnect the driveshaft when towing any automatic with a rear pump. The powershift does. (have one). That is why you can push start a Studebaker with an automatic, the rear pump pressure will engage the clutches it pumps to.Last edited by bezhawk; 07-15-2017, 06:26 PM.Bez Auto Alchemy
use the trailer or remove the driveshaft if on a dolly. i learned the hard way a few years ago. cost me $1,200 for repairs.Kerry. SDC Member #A012596W. ENCSDC member.
I tow my 66 Daytona thousands of miles behind our motorhome on a dolly. Have used it for 2 summers and about 7000 miles with no problems.
I do not remove the driveshaft, but do disconnect it from the differential. I found that it will lay against one of the mufflers and be secured with 2 large radiator style clamps. I tape the u-joint caps on, put a plastic bag over the joint, tape it onto the driveshaft and also make another wrap over the caps. Just make sure that the driveshaft can't slip out of the trans and loose the fluid. You may find something other then a muffler to use as an attaching point under the Avanti.
Hope this helps and happy towing.sigpic1966 Daytona (The First One)
Here's a cold hard fact: Anytime in doubt, disconnect the driveshaft at the diff. It needn't be totally removed if you can suspend it to a crossmember with some mechanic's wire or equivalent. Wrap your u-joint cups with good tape for the trip.Brad Johnson,
'56 Sky Hawk in process
Some people lock the steering straight, and put the rear of the car on the dolly. that may be another option that would not involve getting under the car every time you tow.Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
I have been told that Studebaker steering geometry does not like to be towed. Tends to go full lock either left or right and stays there. locking or tying the steering wheel straight might help, put if going forward is a problem, how bad could it be going backwards?Originally posted by tsenecal View PostSome people lock the steering straight, and put the rear of the car on the dolly. that may be another option that would not involve getting under the car every time you tow.sigpic1966 Daytona (The First One)
I see you have both a dolly and a trailer. If the Avanti is on the trailer, nothing goes wrong unless it falls off the trailer. With the dolly, there's a chance of something going wrong. Bad bearing, low lube in the diff, drive shaft falls off the wire if disconnected.
I've towed a couple of Avanti's on trailers well over two thousand miles and darn glad to have them on it. Now a tow bar with a Studebaker with unknown front suspension condition, That's a ride that will clear your bowels.
I've towed about 5 different Studebakers using a tow dolly. Never had an issue, but as noted above I would always remove the driveshaft and put a plug in the end of the transmission (to keep the lube in). Kept two good wheels and tires that were to put in the rear for towing.
But......if I would have had a good trailer with electric brakes, and a vehicle of sufficient weight/braking/power to tow it........I sure would have towed them on the trailer!Paul
Winston-Salem, NC
It pays to remember,..for SHORT distance towing, say 25 miles or so, removing the driveshaft, and consequent loss of ATF, is completely un-necessary.
Just make sure the Flightomatic (or even the older 'DG') auto tranny has sufficient fluid, and the range selector is in neutral, of course!
I'd disconnect the driveshaft, just to be safe, but tie it off as mentioned above. That way, no loss of ATF, and easier to reconnect. Just be sure to tie it off VERY securely. I also wrap the u'joint in duck tape, to keep it together and not lose the end caps.
Last month when we were bringing home the '65 from the Chuck Nagel sale, somewhere in New Mexico I think, we passed a sad group of people on the side of the freeway who had been tow dollying a mid-fifties chevy truck. The left rear wheel was gone (broken axle) & the fender & rear bumper was slightly shorter from being sanded off by the pavement while they were trying to get pulled over. It was in the upper 90's too....sure was glad our load was riding on a trailer of known condition.
Mike Sal
