Results 1 to 10 of 10
Thread: Air Cleaner Left or Right-which way is right?
    Jan 2014
    marana, Arizona
    605
    I've seen countless photos of 59' and 60' Lark 259 V8 equipped engine bays. I've seen the air intake filter canister horn pointing both left as well as right. Although I don't believe it's critical, for aesthetics , in which direction should it be positioned to be factory correct?
    Golden Hawk Member
    Oct 2004
    19,682
    It should be pointing to the right. That is the car's right or to the left as you look under the hood from the front. This also applies to later Lark-types.
    President Member WCP's Avatar
    Feb 2008
    Glenburnie, Ontario, Canada.
    1,472
    As you look under the hood from the front, the drivers side would be the right side. I don't think that is what you meant.
    Commander Member
    Oct 2016
    Fanning Spgs, Florida
    50
    No matter where you're standing the drivers side is always the left. (Unless you're in England!)
    Jan 2014
    marana, Arizona
    605
    Thanks for the input. I'll place it to my left as I stand in front of the car.
    Oct 2004
    Montpelier, VT, USA.
    1,066
    Oh Phew, when I saw the title I thought you were starting something political, which is verboten.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    Dec 2005
    Ferndale, WA, USA.
    26,976
    With the Decal (if still remaining) in the Front and Center, when the Intake points straight right, I never could figure out WHY so many are wrong!
    That reminds me of the Post where I posted Pics of all the '59 & '60 Larks and Champ V8's (17 of 'em) with the Hottest Heater Input, Water that SHOULD go to the Control Valve, going to the Heater Core, so that you never can turn off the Hot Water!
    61 Champ1.jpg This one has BOTH Errors!
    Golden Hawk Member
    Oct 2004
    19,682
    Quote Originally Posted by WCP View Post
    I believe that you either misread or misinterpreted what I wrote.
  9. #9
    Feb 2008
    1,472
    No, what you wrote was open to misinterpretation.
  10. #10
    President Member DougHolverson's Avatar
    Apr 2011
    Omaha NE or Soldier IA
    709
    Thanks for the information on the hoses! Now I know why my Champ cab is so hot even with the heater valve lever tie-wrapped down. I will swap hoses around later today or tomorrow.
    1963 Champ "Daisy Stu Bludebaker"- sometimes driver
    1951 Commander Starlight "Dale"- basket case, next project after the Hawk
    1941 Commander Land Cruiser "Ursula"- basket case
