Results 1 to 7 of 7
Thread: Checking on getting the correct valve stem seals for 259
    Speedster Member voxnut's Avatar
    Feb 2013
    Sacramento, CA
    159
    Hi All,
    I've been searching the threads on replacing the valve stem seals - I'm having smoke on start up, and as far as I know they seals have never been replaced. I'm doing my Edelbrock swap over Memorial Day weekend and figured it would be a good time to do the valve stem seals at the same time.
    I wanted to double check on which seals to get. I see some references to Ford 302 seals possibly being a suitable replacement, but they are kinda vague.
    Are they correct? If so, is there a difference between early and late 302s? Which ones should I get?
    Thanks in advance for your time and replies.
    All the best,
    Dean
    Dean Seavers
    Sacramento, CA
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    7,357
    FWIW, engine rebuilders buy them by the box of 500. Stop into a local rebuilder and ask for 9/16"(.562") OD X 11/32" ID positive seals. One Enginetech number is S9210.
    Apr 2005
    SoCal
    4,224
    Brand wise, most all the same...Chevy, Ford, Chrysler.
    They all use 11/32" stem valves, just like the Stude engine, therefore, all of the seals will work, and all are very similar.
    Also see Jacks comment above.
    President Member r1lark's Avatar
    Oct 2004
    Winston-Salem, NC, USA.
    3,717
    Blog Entries
    36
    Quote Originally Posted by PackardV8 View Post
    Jack, is any machining required on the valve guide to use this seal?
    Paul
    Winston-Salem, NC
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    7,357
    Quote Originally Posted by r1lark View Post
    No.
    Oct 2004
    Montpelier, VT, USA.
    994
    I used the Fel-Pro SS 72683 Valve Stem Seal Set (2 sets needed), fits Ford & Mercury 140, 302 engine from 7/15/86-92.
    Didn't do any machining and they work just fine, really cut down on blue smoke.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    Feb 2013
    Sacramento, CA
    159
    Thanks much for all the replies!
    Dean
    Dean Seavers
    Sacramento, CA
