Thread: Checking on getting the correct valve stem seals for 259
    Speedster Member voxnut's Avatar
    Feb 2013
    Sacramento, CA
    178
    Hi All,
    I've been searching the threads on replacing the valve stem seals - I'm having smoke on start up, and as far as I know they seals have never been replaced. I'm doing my Edelbrock swap over Memorial Day weekend and figured it would be a good time to do the valve stem seals at the same time.
    I wanted to double check on which seals to get. I see some references to Ford 302 seals possibly being a suitable replacement, but they are kinda vague.
    Are they correct? If so, is there a difference between early and late 302s? Which ones should I get?
    Thanks in advance for your time and replies.
    All the best,
    Dean
    Dean Seavers
    Sacramento, CA
    7,649
    FWIW, engine rebuilders buy them by the box of 500. Stop into a local rebuilder and ask for 9/16"(.562") OD X 11/32" ID positive seals. One Enginetech number is S9210.
    4,388
    Brand wise, most all the same...Chevy, Ford, Chrysler.
    They all use 11/32" stem valves, just like the Stude engine, therefore, all of the seals will work, and all are very similar.
    Also see Jacks comment above.
    Winston-Salem, NC, USA.
    3,928
    36
    Jack, is any machining required on the valve guide to use this seal?
    Paul
    Winston-Salem, NC
    7,649
    No.
    Montpelier, VT, USA.
    1,066
    I used the Fel-Pro SS 72683 Valve Stem Seal Set (2 sets needed), fits Ford & Mercury 140, 302 engine from 7/15/86-92.
    Didn't do any machining and they work just fine, really cut down on blue smoke.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    Feb 2013
    Sacramento, CA
    178
    Thanks much for all the replies!
    Dean
    Dean Seavers
    Sacramento, CA
