Thread: Changing the spark plugs leads on a 185 cid 6 cyl.
    President Member Aussie Hawk's Avatar
    Aug 2006
    Brisbane, Queensland, Australia.
    1,391
    Is there a trick to threading the plug leads through the lead guide on the side of the engine. The boots on the new plug leads available do not come off to accommodate this. How were they done when serviced?
    Matt
    Brisbane
    Australia
    <img src=http://i911.photobucket.com/albums/ac311/Aussie_Hawk/382540_10151076345149314_1092019127_n-1.jpg border=0 alt= />
    Visit my Blog: http://www.mattsoilyrag.blogspot.com.au/
    6,423
    The only time I ever did this I used spark plug wire sets where one end was cut and the boots and contact parts were attached after the wires were fed through the loom.
    9,447
    All of mine have slip boots on the distributor end. Remove that boot, thread the wire through and put the boot back on. Brand new wires are fresh and flexible, and although it is a tight fit, the boots will move. On old dirty stiff wires, they can seem molded on, but they will come off. At least, that has been my experience.
    Aug 2006
    1,391
    Thanks guys.
    I've secured the makings, so I'll make up a set without boots one end and slide them through then fit them.
    Matt
    Brisbane
    Australia
    3,096
    Yep, spray some WD-40 on the ends and slip the boots off, then slide them through.
