Thread: Carter fuel pump
    Commander Member brooker's Avatar
    Jul 2016
    Victoria, Australia
    49
    Carter fuel pump
    DSC_0090.jpgDSC_0092.jpgJust a quick question the 2 small diaphrams in the valve housing how are they seated , are they a press fitting or screw, one has blown out and need to replace it,Thanks in advance for your Help Regards Ray
    Southern Maryland
    671
    Quote Originally Posted by brooker View Post
    Those are the inlet and outlet valves. What do you think happened to the "blown out" valve? Was it melted by fuel?
    One of several sites that shows how to rebuild these pumps is: https://www.428cobrajet.org/how-to-fuel-pump . This is a Ford high performance pump with three valves, but it's very similar to other Carter pumps.
    Mike M.
    1,218
    Ray the umbrella piece is pressed in. a small flat nosed punch will remove it handily.Luck Doofus
    May 2006
    San Diego, California, USA.
    8,736
    3
    I'm bookmarking that!
    Clark in San Diego
    '63 Standard (F2) "Barney"
    Jul 2016
    Victoria, Australia
    49
    Thanks Mike and doofus all back together and running well,
