After replacing U joints, re packing axle bearings, replacing outer rear axle seals, adjusting axle end play, and bleeding brake line, the test drive was cut short due to extreme brake sensitivity. Just the slightest touch of the pedal sent the car screeching to a skidding halt. I think the problem is in the right wheel. I've taken it apart twice to inspect, but nothing looks amiss. Shoes have been carefully adjusted and so has the parking brake. Any ideas? Thanks.
Brake Lock Up
I've noted that many brake problems of this sort have been traced to the hill holder, if there is one. Bleeding it may help.
Others having worked on these will soon chime in, I'm sure. The proper adjusting of the brakes is critical on this application, but it seems you are already aware of this.
Best of luck getting it corrected.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Also, double check to make sure the adjustment between the pedal and M/C is NOT too tight.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Sounds like contamination. I'd double check the shoes and drums for even a trace of oil, grease or brake fluid contamination. Lightly sand the shoes with 220 grit sand paper, and look for, "wet spots" to show through the dry surface in a few minutes. I'd wipe the insides of the drums clean, then wipe down with lacquer thinner, and then wipe again after dry. If the shoes are not too contaminated, they will probably be OK, but grab initially for a few miles. Riding the brakes, off and on, for several miles, at 35-40 MPH often helps dry them out.
Good luck !
Just going on the info from your initial post, you mention the right wheel as the one locking up. So, how do you get it to release? Do you back up slightly? That's how I would do it when the brakes on my Land Cruiser would temporarily lock after the car had sat for weeks. Another thing to look at is the brake shoe rub blocks, (locator bosses, or any number of names I've heard them called) stamped into the backing plates. I've heard others state that theirs had worn grooves in them causing the brake shoes to snag and bind.
Not to state the obvious, but locking brakes are a sure indication the brakes are getting applied, but not releasing. I would really suspect a hill holder if both brakes locked, but not only one. There was a friend of mine,(RIP) who, not being mechanically inclined, bought a Studebaker with a hill holder that was not hooked up. His mechanic accidentally bumped the linkage arm on the hill holder when greasing the car and neither of them knew what caused the brakes to lock up. They called me, and I drove over and found the problem in a few minutes. The mechanic said he had never seen a hill holder. I moved the hill holder arm back to the off position, and told him to try and find the linkage, since it obviously worked.
In your case, there is something either binding, or mechanically preventing the brake shoe from releasing. You did not mention any action on the brake cylinders except for bleeding. Have you looked behind the rubber cups on the cylinders? Are they free from corrosion? Are both sides of the cylinder clean? If one is corroded, and the other not, the hydraulic pressure will be applied the shoe with the free piston. That could cause the sensitivity to slight pressure, if all the pressure is going to only one shoe due to a cylinder with only one side working. My explanation might be clear as mud, but these "simple" systems are designed to distribute pressure equally. No matter how many degrees you have, or how much experience, they can still drive you nuts trying to identify a problem.John Clary
Don't be fooled by thinking since the hill holder linkage is in off position the hill holder is not your problem. I chased my tail for days working on a 63 R2 Hawk before realizing the hill holder was still in the circuit since brake fluid still circulates thru it with linkage not connected. I disconnected the brake lines at the hill holder and fabricated a " jumper" brake line. Brake lock up problem solved.
Turns out it was the FRONT wheel. Haven't touched this since 200 miles ago when I installed all new stuff there. So, pulled the drum. Shoes, pads, drums - everything ok. Drum not scored but shoe lining auto adjuster was aweful close to the drum. Readjusted this and since the eccentrics were on the loose side, I tightened these up. Seems to have fixed it, although o have no idea why.1950 Champion
1962 MGA
