My wiring diagram shows a 3 terminal gas gage. I have a 2 terminal gage in the dash now. Is it possible this is a 12V gage installed at the time of 12V conversion (12+ ground [now - ground] ) ? I'd like to get the gage working and to install the voltage inverter if necessary.... Don't know that I need one ?
1953 2R6 Gas gage ???
Tags: None
Jack,
I have a NOS early 2R gas gage, 676661, and it has three terminals on the back.
Unfortunately I don't have any of the later gages, 6 or 12 volt, to compare it to.
DanDan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
Your truck may have a 3R (1954) gauge and sender in it. Does this truck have the 2R style instrument cluster with with a long, narrow speedometer and two gauges on either side of it? Or is it more of a square cluster with gauges in the four corners?Restorations by Skip Towne
Originally posted by jackb View PostI have the long rectangular cluster. Interesting that it may be a 2 terminal 6 volt gage. How would I know what voltage the gage is ???Bo
Originally posted by jackb View PostI have the long rectangular cluster. Interesting that it may be a 2 terminal 6 volt gage. How would I know what voltage the gage is ???Skip Lackie
As I have now changed to 12V negative ground, I'm hoping the gas gage may now work. I have a NOS (6V) tank unit. My dilemma is determining 6 vs. 12 v guage. I don't want to destroy the 6 V gas/dash unit and was planning on a 6 to 12 V reducer from 5th Avenue. Can I assume the 6V tank unit will work OK with the 12V ?
Originally posted by Hawkowner View PostThe ohms resistance is what needs to be matched up wither it is a 6 volt or a 12 volt the sender must match the gauge.thre are charts on the forum that have the ohm specs for the senders.
HawkownerBo
