Thread: Turn Signal inop.
    President Member Lark8girl's Avatar
    Nov 2005
    Indiana, , USA.
    627
    Turn Signal inop.
    On the 1960 Lark, the left turn signal lights come on both front and rear but do not blink.
    The Right side works correctly. How do I go about diag? Thank you.
    Husband of Lark VIII girl.
    4,227
    Often that means only one bulb is lit. Sometimes when a ground is missing, the turn signal lamp will ground itself through the other filament. Did you look at both left side front and rear bulbs? Did you also test them at night with the taillights on and observe relative brightness?
    3,606
    Looking through a welding helmet is a good way to see exactly which filaments are lit.
    4,227
    The test should still be done with the parking lights on. That's the best way to see if one filament is affecting the other.
    Mar 2017
    Holt, Missouri
    6
    I seem to remember on some vehicle that I have owned, that it was caused by the flasher itself. Replacement cured the problem. But most times it's been as stated in Reply #2.
    1966 Y-4 Commander
    1963 8E-10 122 Champ
    May 2015
    Edgemere, Maryland
    44
    Sounds like the left side lights are not drawing enough current to trigger the flasher unit. Check all the connections and grounds at left side lamp sockets make sure you have the correct number bulb types. Try new bulbs . Flasher works for right side so it is good.
    3,606
    When my 50 Champion quit flashing on the right side last fall, I found the connector for the rear socket must have a bit of corrosion. As soon as I moved the wires it worked agin, so I'll have to unplug it and use some grease in the sockets. It's in a position where water off the tire hits it directly.
