Installed new springs from Stude Intl. a couple years ago and thought my rake was ok, but after going to a couple of shows I recently found out my front is 2" too low. How could that be if I have new springs? Did they maybe send me the wrong springs? Too late to return now, but have to fix the problem.
63 Avanti Front Springs Question
Tags: None
Are the spacers there under the springs? Have any rubber body insulators compressed? What makes you think your car is actually 2" too low in the front? Is it body orientation or did you actually measure the distance of the frame from the ground? If you're comparing it to other Avantis, maybe they're sitting too high. If compared to an Avanti II a '63 will sit lower in the front.
Generally, the body rake is body oriented, not suspension oriented. The coils should not have compressed so soon but anything's possible. The cause may well be elsewhere.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
A good spring shop will add a couple hundred pounds of weight to the drivers seat when setting the suspension up.
('If' the car is mostly driven solo..)HTIH (Hope The Info Helps)
To:Jaybot,---Too bad You didn't take that same measurement a few days after springs were first installed. At least You'd have a comparison. Do the tires rub the fenders? If You feel the 'Avanti Rake' is too
drastic, You could install the factory spacers that Gunslinger mentioned.
When my brother inherited my fathers Avanti back around 1967........he put in new HD springs...........he also had the presence of mind to order and install the factory one inch spacers in the front...........knowing how Avantis sag in the front.............the car sits beautiful...........about 12 yrs ago he replaced the rear springs via a spring shop that did HD over the road trucks.....Mack, KW, White, Peterbilt...........anyway the shop lost their shirts on the job.............first they ordered springs for a standard Lark...........to make a long story short..........after getting in HD six leaf jobs, the arc was n/g...................no rear rake............so they had to heat them up and then put in a special press...........those springs went in and out three times...............for 355.00........the car sits beautiful..................but I imagine that the shop owner never did another car again.
