View Full Version : Brakes: Help with rear brake springs - '54 Land Cruiser
BOEING707100
03-19-2017, 04:35 PM
Hello!
I'm replacing the rear drum brakes on my '54 Land Cruiser. I've got everything positioned and now I'm ready to install the springs. I'm having a hell of a time, the lower anchor spring just doesn't want to pull across to the opposite hole. I'm just using a pair of vice grips, which could be the problem.
1) Any particular order on how to install these? Should the bottom spring go in first? And then the top 2 springs? It seems that I need a LOT of force to get these springs spread.
2) Any kind of tools that could help me? Is there a trick to this that I'm missing?
6296062961
Thank you!
Tony
bezhawk
03-19-2017, 04:57 PM
Leave the adjuster out, then install the spring, then grab the shoes, and pull apart to install the adjuster. You have much better leverage on the shoes, than the spring!
BOEING707100
03-19-2017, 05:02 PM
Thanks, Bez. Would you install the top springs before doing this, so that the assembly doesn't fall apart?
Studebakercenteroforegon
03-19-2017, 05:45 PM
Pre-assemble the bottom spring and adjuster first, position the shoes and emergency brake bar, then assemble the upper pieces and springs next. Lastly assemble the shoe pins and retainers. Actually quite easy if done in this order.
Blue 15G
03-19-2017, 06:32 PM
Good advice already given. But also, Brake Spring Pliers are made especially for this purpose, and work a lot better than trying to pull the spring(s) with vise grips.
TWChamp
03-19-2017, 06:34 PM
That's exactly how I've always done it, and it makes it easy.
BOEING707100
03-19-2017, 06:35 PM
Thanks. I was able to get it done the way Bez said on the drivers side. I'll try it your way on the passenger side.
03-19-2017, 08:29 PM
When I say pre-assemble the bottom spring and adjuster, do it exactly as bezhawk says in post #2. And regarding the brake spring "pliers" as mentioned above - you don't really need the action of pliers - just a brake hand tool that will "roll off" the end of the attached spring and also a feature that guides the spring end on for re-attachment.
Dwain G.
03-20-2017, 12:14 AM
This is the best spring tool for the type of brakes on your car. Cheap and available at any auto parts store. The big end is placed over the anchor pin and rotated to lift and release the spring. To install, the small end is slipped under the hook end of the spring and over the anchor pin. The spring slides down and hooks into place on the anchor pin.
62974
Hawkowner
03-20-2017, 12:56 PM
I always start with the shoes off and the adjuster out hook the lower springs to the shoes push the tops of the shoes together install the adjuster separate the top of the shoes and hook the shoes on the upper pin install park brake lever. Install the retaining pins and springs or clips then install the main springs.
kxet
03-20-2017, 06:55 PM
Made a little jack to work on small fork lifts which are close to ground, leave adjuster out,put brakes together with spring in place,put the little jack( 1/8th' pipe with piece of all thread with 2 nuts locked on end and 1 more nut), put it in between ends of lower part of shoes, spread the shoes and put adjuster in. Take jack out and save.Your done.
