What, if anything should be used with the cork/rubber fuel sender gasket? A few years ago, mine started leaking, so I replaced it. a few weeks later it was leaking again, and I was able to tighten the screws a bit more and stop the leak. Then the sender failed, so I installed a new one with a new gasket and new copper washers. That was fine for a while, but it is leaking again.
I don't know if it is just my Champ or all Champs, but the hole in the floor board is not in good alignment with the sender, 3 screws cannot be reached and the sender won't come out of it, so the whole operation requires me to lower the tank and work. I don't want to have to do it anymore, so what should I use to ensure it stays sealed?
