View Full Version : Steering box needed
bobgould
02-27-2017, 04:20 AM
Looking for a good ross steering box or a saginaw replacement for my 1956 hawk Thank you, Bob
64V-K7
02-27-2017, 08:31 AM
For 56' Ross was a manual box only, but can be fitted with a later Bendix (hang-on) type (59 & later) The 56' Saginaw was the available Power Steering system, many parts specific to either sedan or coupe, etc. It's a large heavy system. The York Swapmeet is coming up in March. You could probably find either one there..
GrumpyOne
02-27-2017, 10:11 PM
Try and find a Saginaw box off of a '56 Champion c/k and it will be a big improvement plus it can be rebuilt while the Ross cannot...
Bo Markham
02-28-2017, 06:30 AM
Why can't the Ross unit be rebuilt?
sweetolbob
02-28-2017, 07:52 AM
I believe I still have the Ross box off a 58 4-door. I'll look for it if is the same as the 56 and add a picture. Bob
GrumpyOne
02-28-2017, 10:10 PM
I take it that if Lars cannot, no one can. All '56 Power Hawks are afflicted with this issue. Don't ask me how I know...
4jc8z
03-01-2017, 11:36 AM
Some 1955 & 56 V8 C&K cars built in Canada had the 53-56 'champion style' saginaw manual steering gearboxes....so yes, the factory used them on some V8 cars.
Bo Markham
03-02-2017, 08:23 AM
Despite the assumption, Lars is definitely not the end all to rebuilding, or restoring gear boxes. We've been doing this sort of work, continuously since 1939.
64studeavanti
03-02-2017, 09:34 AM
I may be wrong, but I believe that the only problem with Ross boxes is limited to Avantis. Basically the problem is lack of parts availability. If there is a source for the internal parts such as the cam (worm gear) and follower arm i would be eternally grateful if this information could be shared.
GrumpyOne
03-03-2017, 12:31 AM
Lares rebuilds the Champ boxes which are essentially the same as the Avanti boxes (through Rock Auto).
http://www.rockauto.com/en/catalog/studebaker,1963,8e7,4.2l+259cid+v8,1491564,steering,steering+gear,7416
Bo Markham
03-04-2017, 05:44 PM
Drop me a note, I may be able to help you with an Avanti gear box.
52 Ragtop
03-04-2017, 06:50 PM
IF it's a matter of a particular part that needs re-manufactured, I deal with a couple of excellent machine shops, and Dan is pretty willing to make just about "anything"
Jim
doofus
03-05-2017, 07:36 AM
LOTS OF ROSS BOXES IN FORK TRUCKS, do some home work and you may find what you need. Luck Doofus
64studeavanti
03-05-2017, 01:43 PM
Bo, I have plenty of used. Do you have any NOS?
Doofus
I believe later Avantis did use fork lift boxes - so the rumor goes. In any case, the one on my 78 is quite different from the Stude ones.
Bo Markham
03-05-2017, 05:18 PM
Doofus
Yes to NOS. Fork lift boxes were used on certain Avanti II's.
03-05-2017, 05:33 PM
It's going to need to be a Saginaw from a C or K, not Sedan or Wagon.
A 1956, would be a Flight Hawk 6 as I assume GrumpyOne has.
03-05-2017, 05:37 PM
If "we've" includes YOU, you must be 97 Yrs. Old! :ohmy:
Bo Markham
03-06-2017, 06:16 AM
Mr. Gahlbeck,
Some times I feel about 97 years old, but I'm not quite there, yet. I'm merely the current generation keeping it moving forward. I usually keep a dozen, or so NOS and remanufactured boxes on hand. When required, we do machine work, too. Some times, you just have to bite the bullet and make a part.
How about you, young man of 88 yourself?
bobgould
03-08-2017, 03:21 AM
Mr. Gahlbeck,
:):)Lares said they could rebuild my box if they could find a good worm shaft not to readily available! It could take some time till they could find one
- - - Updated - - -
Mr. Gahlbeck,
:):)Lares said they could rebuild my box if they could find a good worm shaft not to readily available! It could take some time till they could find one.
Bo Markham
03-08-2017, 08:02 AM
- - - Updated - - -
Yes sir, I suspect they could. If/when they could find the necessary parts. Not having inspected your box, can't really tell what parts actually need replacing? The only thing I can tell you is it needs to be looked at, or replaced with an NOS, or rebuilt one. You might even try Myers?
bobgould
03-11-2017, 06:09 PM
Can you rebuild the worm shaft or have parts for one?
bobgould
04-07-2017, 03:36 PM
If you can rebuild my box which has a worn worm at the center position please send me an address and I will ship it to you. Thanks Bob. 1956 Power Hawk
mbstude
04-07-2017, 05:00 PM
In inventorying parts this week, I found an NOS steering shaft and worm gear (with cups and bearings) for a 53-56 C/K with the Ross TL box. If your Power Hawk has a type TL box, you'd be set.
http://mystudebaker.com/
joegood
04-07-2017, 06:42 PM
I just replaced my Ross box in my 56 hawk with a saginaw from s 63 lark. It took some work and a steering U joint but the end result was well worth it.
WCP
04-07-2017, 09:13 PM
I have a Ross box removed from a '62 Hawk many years back. The Hawk had approx. 75000 miles and the car had power steering, so the box has little to no wear. If interested, PM me. Price $50us plus shipping.
