The one I am talking about is a tear drop and is next to the trunk latch. I was wondering if a light was planned and was not put into production after the stamping was modified?? . just noticed it when replacing my trunk pan. Might be a spacer to keep tire off of the latch???
What is the lump in the very back of the trunk compartment on my Hawk for???
I think he is talking about the bulge in the rear trunk wall of some years of C & K Models.
Everything has a reason, but that one I am not sure exactly what it is.StudeRich
Originally posted by rockne10 View PostA photo would help.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
You are correct. it is at the rear of the trunk. it is not the spare tire bulge with threaded hole. my donor 55 commander trunk pan has it. My skyhawk has it. I am thinking most all hawks have it. Teardrop shap next to trunk latch late. I will try to get picture. Did not mean to make people mad because no picture.
Originally posted by StudeRich View PostI think he is talking about the bulge in the rear trunk wall of some years of C & K Models.
Originally posted by cabforward View PostDid not mean to make people mad because no picture.Brad Johnson,
'56 Sky Hawk in process
Brad Johnson,
I've always figured it was to help position the spare. If you look at it with the spare in place, it makes kind of a flat area for the tire to rub on and keep it from moving around. I think this would be more noticeable with a original type bias tire as compared to the photo of that radial.
I've got a "semi-donut" spare in my '53. Its about normal diameter but thinner. Intrudes less in the trunk for more luggage room. Came from a lincoln town car. I don't use the big hold-down disk but rather ran the hold-down bolt through one of the lug nut holes. That shifts the wheel closer to the back and it sets nice and snug up against that bulged spot.
If its not for locating or securing the spare, I have no idea what it would be for as there is nothing inside the rear box section of the body or way to get inside there. The factory accessory trunk light mounts to the underside of the lid above the lock and the better place for it to light up the inside in the dark.
Jeff in ND
Originally posted by rockne10 View PostCuriously, now that the culprit in question is photographically identified, exemplified as well in my '53 Coupe, I can see absolutely no functional or structural application.
But a few '53 body panels had stampings in them for items that never appeared in production, such as the second interior door handle on C/K models.
