A word to the wise if you are thinking of cutting the swedges off the wheel studs do this first drill and tap the drum for a 1/4 in drum and hub counter sink the hole in the drum and when you reinstall the drum fasten the drum to the hub using flat headed bevel screw.These bevel screws will center the hub and drum like it was before swedges were cut.
Some one had cut the swedges off of my GT s drums. One drums is good but the right drum had too much metal removed and is causing problems,
Hawkowner
Hawkowner
