Can anyone suggest where to buy all the glass rubber for the '39 commander? including the vent window rubber, and the door glass anti-rattle strips (not the window channel)? Valerie Hansen does not carry the rubber.
Also what is the original thickness of the door glass? my existing door glass and vent window measures .210" thick...kind of odd size? did the lamination swell from 3/16" or was it .210" thick from the start? Just curious if I get 3/16" thick door and vent window glass, will it be loose in its metal attachment frames? I will be using new glass setting rubber strips in the frames. Its probably not enough to worry about, and may make it easier to go in. I just find .210" thick is a little odd?
