View Full Version : Brakes: Hill Holder/no-rol parts
kamzack
02-04-2017, 05:00 AM
Need brackets and hdwe to attach arm to clutch and diagram or description of brake line routing. Intend to install on my 61 Champ.
Kim
Hawkowner
02-04-2017, 08:00 AM
Just took one off my GT mine bolted to the frame with the bolts that held master cyl. The master was on out side of frame no roll was on inside. 8 inch U shaped brake pipe from banjo fitting on the back of m.cy u shaped over the top of frame rail connected to the no roll.Two out lets from no roll for front and back pipes. 8 inch adjustable spring cushened rod with a 90 deg bend inserted through hole in clutch pedal and to a lever 2 1/2 in lever on the no roll .Sold and shipped the parts yesterday
Hawkowner
kamzack
02-07-2017, 03:19 AM
Thank you for that instruction. PM sent
Kim
rkapteyn
02-07-2017, 07:27 AM
You can order templates from this site.
http://www.studebakerdriversclub.com/Studebakertemplates.htm
I do not have my parts books here at the house but you can look up the accessory kit number (ACXXXX) listed for your vehicle and see if that sheet is available.
It will give detailed instructions and sometimes a detailed parts list so you can order the parts you need by part number.
kamzack
02-08-2017, 03:39 AM
Thank you much,
Kim
