We are in the process of building an R2. for a 1960 Lark We have some questions.
Are the same parts used to build an Avanti R2 as a regular car with an R2?
An R2 needs to run an Avanti vibration damper and pulleys. If not, what should be used.
We understand that you should use an Avanti water manifold which is what the water pump mounted in. The parts book shows that both the R1 and R2 Avantis ran the same water maniflod. Is this correct or should something else be used?
Thanks for your help and information!
