I have searched high and low, but can't find anything showing the distance from the plane of the block at the bell housing mounting and the surface of the flywheel mounting on the crankshaft. Also if anyone knows, the depth of the pilot hole drilling in the crank end. If you have those you might also have the measurement of the crank face to the flywheel clutch face. I have read a bazillion swaps and "what works" articles, but rather than taking everything apart and do those measurements myself, it would be nice to have them. As mentioned before, I'm pulling my Power Shift and converting to currently available manual transmission using a 61-62 GM pattern bell. All the articles I have found seem to miss something or other, eventually getting it to work, but some minor critical info is missing in each article. These measurements will allow me to calculate exactly what I need to make and modify to get it right the first time. Thanks for any information you can provide or a link with that info. I have all the articles written and found at Bob's--still a few missing pieces.
Digram with crank flange to block measurements
FWIW, I've done many transmission conversions and always begin with the OEM transmission input shaft length and pilot dimension. Match that and you know you'll be good to go.
I know the more common Studebaker and Packard V8 transmission input shaft dimensions, but don't have one for the Chev pattern Stude T10. Any reason to believe it's different than the others?
jack vinesPackardV8
Fred, I measured 3 289 cranks. The depth of the pilot bearing hole in the crank ran from 2.293" to 2.310". From crank face to flywheel face will be all over the place, since you don't know how many times the flywheel has been surfaced and how much has been removed, or the depth of the register in the back face of the flywheel. For those I can give you no hard and fast dimensions.
Originally posted by PackardV8 View PostFWIW, I've done many transmission conversions and always begin with the OEM transmission input shaft length and pilot dimension. Match that and you know you'll be good to go.
jack vines
Originally posted by Alan View PostFred, I measured 3 289 cranks. The depth of the pilot bearing hole in the crank ran from 2.293" to 2.310". From crank face to flywheel face will be all over the place, since you don't know how many times the flywheel has been surfaced and how much has been removed, or the depth of the register in the back face of the flywheel. For those I can give you no hard and fast dimensions.
Fred, I measured from the crank flange to the face of the flywheel with a new flywheel and found 1.115". It would be nice if you put up a diagram of the dimensions you need. From the face of the flywheel to the block is 1.888". Hat height? Flywheel mounting face to block mounting face .773".
Thanks Allen,
This supplies all my missing numbers. I have the cutaway drawing almost complete with all the dimensions overlapped in cross section to show the original assembled configuration. That way it will be available for anyone wishing to do a conversion or trans transplant. Give me a day and you'll see why I wanted this for my use.
Originally posted by Alan View PostThe hat height is 6.950" +or- .010". I set up 6 Stude housings on my granite table and they ran from 6.938" to 6.953".
