Hello, I know this is a strange question and I am sure there will be some funny comments, but here it goes. In California, all the gas pumps have a fume capture system. With the angle of the filler neck at the rear of my 63 Cruiser, it is nearly impossible to fill the tank without spilling over on the bumper and ground. Any tricks or adapters? Thanks, Steve.
Filling tank without spilling
Fuel System: Filling tank without spilling
Steve Nowicki
Davis, CA
1963 Studebaker Cruiser
289 V8 2bbl
Flight-o-matic
Twin Traction Dana 44
Factory front power disc brakes
Rose mist with Chestnut interiorTags: None
I have found this to be difficult as well. If your Cruiser has the factory rear license plate mounting bracket, I would take it off and buy another bracket that would position the license plate an inch or so lower. I have done this and it really helps. With the plate thereby lowered, the pump's filler neck assembly can be held more vertically, which seems to help. With the license plate in the factory position, I was always fighting the top of the plate with the pump handle.
Also, when you know you are almost to where the pump is going to click off, slow down on the handle trigger.
I just Park it nose down whenever possible, put the front wheels off of the Concrete slab that is always near the Pumps, and onto the lower Blacktop, after the tank is half full, run the Pump on the slowest speed, well into the filler as far as you can and after the first shutoff do not put much or any more in.
Works for me on the '62-'66 Sedans with those Low Fillers and short Pipes.
But I realize it is much easier here where we don't have that strong spring and vapor seal to force into the filler like I have to use when in Calif.
Be sure you have a non-Vented Cap.StudeRich
I bring a 1' rubber hose that slips over the nozzle then pull back the bellows & fill. These darn Jerry Brown-California Air Resources Board things I think are figments of some backroom nimrod that drives an electric car & has no idea how these things perform. Plus that electric car pays no road tax that all the rest of us with our left over dinosaur remains use & pay. Same mentality goes for these gas cans that now are missing the vent. I'd like to see one of these nimrods show how they can be used without spilling so much gas that whatever vapors may have gone into the atmosphere before are more than compensated by the spillage these new cans produce!
I am now leaving my soap box. You may return to your usual programming.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
We don't have the California nozzles but the standard auto-shutoff is usually a splash late on my 41. I just use my ears. I can hear when the level hits the fill pipe and I stop it manually. Since I buy gas about times a year whether I need it or not being careful is not much of a hassle.
Nathan
Posted by warren webb
Find many great new & used options and get the best deals for EZ-POUR 30051 HI-FLO Replacement Spout and Vent Kit at the best online prices at eBay! Free shipping for many products!
Bob
my 60 isn't quite that bad, but I have the same system on my 65 Skylark. I rotate the nozzle 45 degrees from true vertical (using the nozzle itself as an axis of rotation) and it seems to work fine like that.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by Mohr HP View PostModern pumps fill much faster than the old ones did. The real issue is that our old filler's vent tube diameter is too small. I put a 3/4" vent line into the new tank I installed in my car. Problem solved."In the heart of Arkansas."
I not only have the same problem of over filling but being as I am 6'6" tall, bending over to fill the tank is a real pain. I put new rear springs on, hoping that would bring the back end up, but to no avail.
Mark
Originally posted by 52-fan View PostSome of the places I buy gas the flow seems very slow.Brad Johnson,
'56 Sky Hawk in process
