I know this has been asked before but can't find the thread. Who makes the extra loud flasher unit I've had two different ones in my GT and I still can't hear it.
Extra loud flasher
Tags: None
And while we're at it how about brighter lights for turn single indicators. I find myself getting out and checking all the time because I can barely see the indicator lights. Is there an LED that just plugs into the same socket? Seems to me that I've seen that here some time ago.I'd rather be driving my Studebaker!
I tried one of these flashers because it worked with LED lamps. I didn't know it had a beeper in it when I bought it, it worked fine but I replaced it because it was ungodly loud. My car is pretty quiet inside. http://www.ebay.com/itm/Turn-Signal-...YAAOSwofxUfzAU
I use these LED's in my dash indicator lights, they're a lot brighter than the incadescents that were in there. http://www.ebay.com/itm/20-BA9S-Whit...item33958e6b1e
This company has just about anything you need, except I don't think they have a flasher with a beeper.
Shop our wide selection of LED replacement bulbs for cars, trucks, and SUVs! Browse headlights, tail lights, brake lights, turn signal lights, and more!
LEDs are very voltage sensitive. Some automotive LED replacement bulbs have a little voltage regulator built in, and will work over a wide range of voltages. Others have resistors built in to drop the voltage, and can be dimmed - mine are like that because I built them myself. But a very small change in voltage causes a big change in brightness, and they might not even come on if you drop the voltage very much. I think the ones sold by Superbright are most likely not dimmable - you should call and ask one of their tech people.Trying to build a 48 Studebaker for the 21st century.
See more of my projects at stilettoman.info
I thought Stude drivers were like Buick drivers......driving 20 mph slower than everyone else in the fast lane with their left turn signal perpetually on??Bez Auto Alchemy
Originally posted by StudeRich View PostLoud Flashers should only be a bit louder Clicking sound, no beep. They should be at your Parts Store.
I replaced the turn indicator bulbs with LEDs, amazing difference in brightness!!! I also replaced the flasher with an electronic type that has a fairly loud click, not annoying but audible. I would think that a flasher with a beeper could be wrapped with some sound dampening material to attenuate the sound level.
LEDs are generally dimmed by varying the duty cycle - the ratio of on time to off time.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I have been tweeking things on my GT. I have the He problems with dim pilot lights and the broken cancel lever plus the the handle for the signal handle was loose and floppy so it was hard to tell if signal was off or on. I bought and installed new cancel lever works good now.
Hawkowner
Originally posted by StudeNewby View PostBen, I'd assume the LED brightness is not adjustable via the light switch?
