65 cruiser front shock mount
The correct bolt center to center on the lower cross pin for a Studebaker front shock ('57 and up) is 3-1/4". I have seen some people use a 1970s MoPar front shock which has a 2-7/8" center to center. Plus the MoPar shock is a little short as to extended length. I think the big washers shown were use to fit MoPar shock. No worries, the correct Studebaker front shock is readily available.
These could be Camero Shocks also, whatever they just are, just not the Gabriel Classic Gas Shocks that actually Fit '57 to '66 Studes.
Nothing is missing from this Car except a bit of proper research to find the correct Parts at:
Originally posted by thunderations View PostOriginally there were nuts welded on the inside of the lower A arm and bolts went up into them to hold the shock up.
Could be, without a Part Number we have no clue. Are they Gabriel Classic Gas or not?
Post #2 over here, has what you need:
http://forum.studebakerdriversclub.c...ghlight=shocksStudeRich
I am building a 66 cruiser for my daughter and just put the correct Gabriel shocks on this weekend. They are held on with carriage bolts from the top down as yours are. If you want the correct shocks I got them on Rockauto.com for $20 a piece. You have to search the part # they're not listed under the vehicle. Part # 82087 front 82103 rear.
You are correct. I was thinking of my T-Bird front end. I always thought the Studebaker would be better with nuts welded onto the lower A arms. Just driving the car messes up those threads hanging down and makes it tough to remove the nuts without ruining the bolt when it starts spinning.
Originally posted by Studebakercenteroforegon View PostNo...there were two bolts with a carriage bolt head that dropped down through a square hole in the control arm that kept them from turning when tightening the nuts from below. The original bolts were fine threaded, but if I need to replace them I use a hardware store carriage bolt (coarse thread) and a nylock nut.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by hughbe View PostThanks for your help, glad i found this forum
Chris.
