New Dual Hydrovac
  • Brakes: New Dual Hydrovac
    I had not seen these in some time, but apparently they are being made again. Probably same place SI is getting their repops.
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    Doesn't look like it has any provisions for dual braking though.
      The instruction :
      When plumbing the unit, the front brake
      port on the firewall mounted master cylinder will go from
      the master cylinder to the Inlet port on the booster. The Outlet will then route from the booster to
      the front brake calipers. See Figure 1 below for port locations
      . It does not matter which side is
      plumbed for the front or rear.
      For vacuum, connect both halves of the booster together with
      vacuum hose and a vacuum “T” and then connect to the engine or an electric vacuum pump
      Would like to see picture of all views and the manufacturer info I contacted them waiting for answer to use with dual master cylinder
