What all would be involved in swapping a '63 Lark Cruiser drivetrain into a '60 Lark Wagon? The '63 has a 289 w/ AT / Power Steering and the '60 is a 259 w/ 3 on tree. I am assuming that the driveshaft would need to be addressed to make it fit properly with the AT.
'63 Cruiser Drivetrain swap into a '60 Lark Wagon....
Not too tough on this one. Virtually all parts will interchange as though they were born there. I don't recall the wheelbase on the two cars, but check to see if they are the same. If so, even the driveshaft will swap over. Do you have the rear end from the Cruiser also? If so, swap that in too. The brakes should be the same or very close to the same. But just in case keep the Cruiser brakes too. The frames are same except for the length, but check that to be sure, so the suspension will be easily exchanged. Its one of the easiest swaps to do. Change out the steering column so you have the shifter and indicator for the automatic. All that linkage will bolt in too.sals54
Infidel,
So what's wrong with the 259, three speed? Unless the original is trashed I can't see any reason to put a great deal of effort into a project for very little positive return! By the way, you are probably not going to get away without also changing the rear-end, because of the different gear ratios. Both cars should have a Dana 44, so except for the 63's self adjusting brakes the swap should be pretty straight forward, but again why go through the trouble?
Well... For starters, many of us older lazier types would prefer the automatic which should be the heavy duty version since it's coupled to a 289.
But that's just me but I do fit the personality of old 'n lazy..
Originally posted by sals54 View PostNot too tough on this one. Virtually all parts will interchange as though they were born there. I don't recall the wheelbase on the two cars, but check to see if they are the same. If so, even the driveshaft will swap over. Do you have the rear end from the Cruiser also? If so, swap that in too. The brakes should be the same or very close to the same. But just in case keep the Cruiser brakes too. The frames are same except for the length, but check that to be sure, so the suspension will be easily exchanged. Its one of the easiest swaps to do. Change out the steering column so you have the shifter and indicator for the automatic. All that linkage will bolt in too.
So what's wrong with the 259, three speed? Unless the original is trashed I can't see any reason to put a great deal of effort into a project for very little positive return! By the way, you are probably not going to get away without also changing the rear-end, because of the different gear ratios. Both cars should have a Dana 44, so except for the 63's self adjusting brakes the swap should be pretty straight forward, but again why go through the trouble?1960 Lark VIII Regal Wagon
Originally posted by GrumpyOne View PostWell... For starters, many of us older lazier types would prefer the automatic which should be the heavy duty version since it's coupled to a 289.
Normally Standard, non "R" Series, 289's did NOT have H.D. Flight-O-Matics.StudeRich
Maybe that's His personal preference as a combo?, Factory or not.
Originally posted by StudeRich View PostJoseph R. Zeiger
That would be fine Joseph, but THAT is NOT what the Man said!
You need to learn to READ what people actually SAY, not what you THINK they may have.
If uncorrected, these incorrect statements tend to mislead the newbies that want to know how they actually were built to know what to expect if still original.StudeRich
You mean to say that the engine/PowerShift combo that I removed from a '63 Hawk wasn't HD as the engine was a standard run-of-the-mill 289, not an R series!
I don't profess to know it all but can cite my personal experiences.
(snort)
(snort)
Treblig
Originally posted by StudeRich View Post1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 Avanti
Many questions on this forum can be answered by going back to the forum archive and look at the posts.
108 pages with thousands of posts.
http://forum.studebakerdriversclub.c...x.php/f-8.html.
Many forum readers probably do not know that this archive is available.
Robert Kapteyn
Originally posted by rkapteyn View PostMany questions on this forum can be answered by going back to the forum archive and look at the posts.
Robert Kapteyn
Just because someone remembers a thread covering a topic 5 years ago, doesn't mean the question can't be answered again.
Excellent point Matt !!!
Originally posted by mbstude View PostWhile a good source of info, it's a lot easier to start a fresh thread than it is to potentially spend hours trying to find an answer.
Just because someone remembers a thread covering a topic 5 years ago, doesn't mean the question can't be answered again.Joseph R. Zeiger
