I realized nine years ago that the Speedster I had just bought had inoperative front parking lights, but the turn signals flashed, so I left them alone. I likely should have continued to ignore them. While thoroughly cleaning the front lenses and internal reflecting surfaces last week, I thought I would replace the two #1158 bulbs. That's when I realized how bad the sockets were. One bulb was extracted in pieces using long-nose pliers. I was able to easily clean the crud from the contacts of both sockets, but the corrosion of the inside walls of the sockets and failed springs for those contacts mean dubious function of the new bulbs. I know that the short answer is to replace the sockets. They seem to be pressed into the big diecast side grilles/lamp housings. They easily rotate a little. Can they be safely pried out and replaced from the front without dismantling everything (from fog lights and bumpers to the three massive chromed grille sections)? I did find a source for sockets for 1158 bulbs (from another forum thread.) Would there likely be enough length of wire behind the socket to work with?
As far as the parking light function, would be great if they worked on a Speedster with everything else working (except clock). Test light shows there's current to the terminal at the junction block, so problem lies between there and the sockets. But I'm more concerned with the directional signals. Maybe I should practice my hand signals.
Gil
Gil
