Can anyone identify part
Tags: None
It looks sort of like a fragment of a thrust bearing from inside a manual transmission. If it came off your car at all, I'm thinking it was a piece of something, used as a shim under the left side rubber mount between the bell housing and frame crossmember. There is supposed to be a half-inch thick steel washer there, but maybe some prior owner put in stack of whatever?Gord Richmond, within Weasel range of the Alberta Badlands
